No cooling at all. Fans run but compressor not working. Any thoughts where to start?
there are 4 plastic pin, just get needlenose pliers, and sqeeze the pin while pulling the board out.
Just take the wire connections off the board, they pull off, and can only go back on one way
put the board back in, yes the compressor should start right away
The f-2 light goes on and oven shuts down. I took off the back cover,played with a few wires, wd-40ed it and it worked for a few days and now I’am back where I started. Do I need a new oven control unit or what?
john L.
I have a ge front load electric dryer that is around a year old that does not run for more the 2 min. in sensor dry mode but in timed mode works great any help and or diagrams would be awsome thanks
I had my GE Profile PSS26NGPAWW fridge cut out (fans all blowing but compressor not making cold) about three weeks ago. Cleaned all the dust etc. from the back and let it manually defrost although there was no ice buildup near the evaporator. Fired back up and ran fine. Last night it did the same thing again although this time after a lengthy manual defrost, it didn’t come back on. Found this thread and verified the circuit board was burned under the compressor relay. Re-soldered it and it is back up and running. Thanks abadfish66! Now, the question is why did it burn there in the first place and will it happen again?
