GE Front Load Washer won't spin
Hi All,
My GE Front Load Washer, Model WBVH6240HWW, recently stopped spinning. If I program it for a wash (say, quick wash), the machine first drains for a few minutes, and then it stops. I tried the following so far, and the problem remains.
  1. Cleaned the filter in drain plug.
  2. In "Service Mode", "E54" were recorded in "T02" before I started any test.
  3. Did the following tests:
t04: OK
t05: OK
t06: OK
t10: beep twice and nothing happens
t11: beep twice and nothing happens
t14: The test is not listed as an option. Goes to t13 only
Did some research on the forum (mainly http://forum.appliancepartspros.com/washer-repair/26788-ge-front-load-washer-wont-tumble-spin.html). Learned great deal from the discussion). It seems the fingers point to either the Control Board Assembly (AP3995160) or the Inverter (AP4421584). Any help in identifying the part to be replaced would be greatly appreciated.
Best,
Haigang
Any help would be greatly appreciated. Thanks.
Just a status report. First replaced the Control Board Assembly. It did not resolve the problem. Then replaced the Inverter. Now the washing machine is working again.
One thing still puzzles me though. t14 is still not listed as a test option. Test options go to t13 only.
