This front load spins out fine when there is no load. When it is under a load t makes noise and barely spins. I looked at suspension and all appears to be fine, and do not see any thing else that appears broken. Any help would be appreciated as to what to look into on this machine. Thanks!
Check the belt?
— Begin quote from RKF22;803091
Tub & Motor parts for GE WCVH6800J0MS - AppliancePartsPros.com
Thanks for the help.
