GE front loader won't spin in a regular wash cycle, but spins fine during drain/spin
The GE front load washer will not spin when in a regular wash cycle. It fills and drains fine, but doesn’t even attempt to spin. The system times out and the start button flashes. If I put it on drain/spin, it works like a champ. What gives?
Hello,
What is the complete model number of the washer?
Wcvh6800j1ww
Ma202573t
Run the washer in the service test mode as instructed in the attached file and post the results.
Here are the breakdown diagrams and http://www.appliancepartspros.com/parts-for-ge-wcvh6800j1ww.html
I just had a GE repair man tell me it was my circuit board. Even tho all lights and cycles work. I’m not that bright, but I don’t understand how if everything else works, how the circuit board is "fried." He advised me to buy a new one. This is only 3 yr old!! Is this common for GE?
You still can do the diagnosis yourself.
