My GE front-loader washer advances through the cycles, but will not drain or spin at the end. During the spin cycle, I sometimes see it agitating as it does during the wash cycle.
I have read other threads here about similar problem with the Frigidaire version of this washer.
Recommended solution was check/replace door lock - see http://forum.appliancepartspros.com/washer-repair/513059-frigidare-washer-front-loader-fills-water-no-spin.html
Recommended solution was check/replace motor/speed control unit - see http://forum.appliancepartspros.com/washer-repair/514512-washer-wont-spin.html
Recommended solution was check/replace pump - see http://forum.appliancepartspros.com/washer-repair/498053-frigidaire-front-loader-wont-spin.html
Any help appreciated - thanks.
