ge gas drier not advancing
My ge gas dryer works fine and dries fine. The issue I have is that the timer wont advance. Is it as simple is it sounds to replace the timer? It is a ge dryer model DBXR453GVOWW. Plese get bck
If there is power to the timer motor then the timer is the culprit.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=206973
