GE hydrowave wbsr3140g0ww top load: Timer knob and timer not in sync
GE hydrowave wbsr3140g0ww top load: Timer knob and timer not in sync. Cycles whatever it feels like, certainly not what the knob is pointing to. It fills with water and drains almost constantly. Pulling/pushing the knob doesn’t stop or start any cycle - it just keeps partially filling and partially draining regardless of whether it should be on or off. I’ve taken the knob off the front of the control panel and also the timer from behind the panel. I can’t seem to get them working together in the correct cycle properly. I’m ready to use the Tim Allen approach and replace it all with super-massive industrial parts. Or more likely get my fave baseball bat and let it have what it deserves…Help!!!
On another note-I’ll be posting for help with a GE Hot Water Heater that keeps tripping the breaker.
I have a machine with exactly the same problem. When placed in HEAVY it starts off by draining and spinning
Hi,
What is the complete model number of the washer?
Please describe the problem more detailed.
