GE not draining properly
[SIZE=3]I have a GE dishwasher (gsd4940c02ss) that is not draining properly.[/SIZE]
[SIZE=3]At the end of the wash cycle, the drain pump only runs the last ten seconds of the two minute drain cycle. Only draining a portion of the water in the tub.[/SIZE]
[SIZE=3] [/SIZE]
[SIZE=3]I have replaced the drain pump, the sequence switch as well as the control assembly.[/SIZE]
[SIZE=3]It appears to be a timing issue. How do I get the drain pump to run for the entire drain cycle?[/SIZE]
