[SIZE=3]Both refrigerator lights are out. I’ve replaced the bulbs, although the original bulbs were good, turned the circuit on & off, to see if circuit problem and still the light do not go on. The rest of the unit is fine. Could it be the switch & how do I change it?[/SIZE]
The switch will pop out with a small screwdriver. Connect the two wires to bypass the switch and see if the light works.
Thanks for the help, I’ll give it a try.
