Last week, my 5 year old GE Side by Side fridge stopped working. Here is a summary of the details.
Interior lights on both sides(fridge & freezer work). Nothing else works - No fan / compressor, the icemaker / water dispenser LED control is out, the digital temp control is off as well.
After doing some research on this forum, and further troubleshooting I assumed that it had to be the main board that was out. I removed the back cover for the compressor / fan and the one for the main board. I checked for "burnt smells" - there were none. Eventually I removed the main board controller and it looked okay but I was certain that the problem was here given that nothing else was functioning except the interior lights, and I could not locate any fuse anywhere. Also I assumed that if the relay and overload was out it would not stop the LED icemaker control on the front and the temp control inside from coming on. Hence, I came to the conclusion that it must be the main board…
So next I order the replacement board from here (WR55X10942) and installed it… drum roll please,
After I installed it, nothing changed… no compressor or fan, no LED’s working, nothing… only the interior lights working as before.
So now I’m puzzled. I re-checked my connections to the board and everything seems fine…
So I am stuck and confused as to where the problem might be.
I would be very grateful if one of you experts could point me in the right direction.
One last thing, I did notice a small amount of water in the tray that sits below the compressor /fan in the back bottom part of the fridge. I assumed this to be normal and associated with the evaporation due to the loss of coldness when the fridge first went out
