GE washer doest fully drain
Always problems
Usualy wont rise fully evertime so we have to do a second spin rinse. and usualy well still have water in the bottom outer tub just enough to hear and see it under inner tub.
what should i be looking into to fix, pump?
[SIZE=3]You will always have some water under the spin basket but I am unsure how much you are talking about. One way to tell if the pump is doing its job is to take the drain hose and point into the washer tub and then turn the washer into a spin cycle. Once the washer starts to pump there should be a full stream coming out of the hose. If not the drain hose may be partially blocked. If it seems to be pumping fine the washer just may not be spinning fast enough. The belt may be slipping because its worn or because its getting water or grease on it. http://www.appliance-repair-it.com/clothes-washer-repair.html[/SIZE]
