ge washer - need motor test procedure
washer agitates, drains, but does not spin.
not the cover switch, and the belt and pulley freely turn by hand. Can someone give me a way to test the connector wires, both for motor continuity and to test the voltages from the panel end of the connector at the different cycle points? Any other suggestions welcome. Thanks
david
