I have a GE Profile WPRE6150k1WT washing machine that seems to be getting stuck in the spin cycle. It isn’t happening every time, but is getting more frequent.
I have had occasions that the clothes are still wet and not spun out at all, but the water is drained from the tub.
I have pulled the front cover off the washer and checked for codes on the motor board. There were no codes. The LED flashed at a steady rate. I checked the coil on the Mode Shifter and I have 66 ohms on the coil. I believe it should be about 98 ohms. I have watched the washer run, and I see some movement in the basket during agitation.
Any ideas?
