My GE Washer spins very slow, on the fast speed setting. The clothes are so wet that you can squeeze water out of them. What is wrong with it? What part will fix it? Is it something my husband can fix?
[SIZE=3]This washer stores error codes and some of these error codes limit the rpms of the motor. To read the error codes you must look at the flashing light on the motor. I suggest if you have a error code clear it as described on this page and if it returns replace the part suggested on this page. http://www.appliance-repair-it.com/GE-washer-repair.html[/SIZE]
