Help My Whasher Do Not Spin
I’VE HAD THIS WASHER FOR LONG TIME AGO AND I NEED SOMETHING.
MY WASHER WORKS WELL BUT THE ONLY THING ITS NOT WORKING ON SPIN CYCLE. IT DO THAT BUT TOO SLOOOW.
WHO KNOW ABOUT THIS PROBLEM. ??? HELP please
Hello. I have sent you an attachment to show you step by step directions on how to correctly diagnose this problem, you either have a bad mode shifter or motor [part]AP4380186][/part] [part]AP4536552[/part] Thank you and good luck !
[SIZE=3]Spinning slowly indicates the motor has flagged an error code, probably the 9 flash error code, which limits the motor to 50 RPMs. Most of the time clearing the code will take care of it but if the problem persists replace the motor. Here is a link that may help. [/SIZE]
[SIZE=3][/SIZE]
[SIZE=3]http://www.appliance-repair-it.com/GE-washer-repair.html[/SIZE]
[SIZE=3][/SIZE]
Thanks for your info. That really help me to solve my problem.
Thanks guys.
