Hello,
My GE washer has a defective spin cycle and clothes are coming out soaking wet.
I ran a full cycle with the lid bypassed and open.
-The wash and rinse cycles appear to be working fine.
-The water drains completely, for an extra small load it only took about 30-40 seconds to drain.
-The spin cycle starts but very slowly. I watched it spin slowly for about 5 minutes and then it turned off like the cycle was complete.
-It sounds like the drain pump is running during the entire spin cycle, should it cut out at some point?
-I get a steady green led blink from the led on the motor.
-The belt looks very clean and tight, I can’t see anything wrong with it.
Thank you for any help!!
Jason
