Got power, but wont start. Imperial Series Dryer
Ok, this is the information on the dryer i have :
[B]Whirlpool
Imperial Series
7 cycles
4 Temperatures
Model # LEN2000KQ1
Serial # MP0644521
Type : DWSR-ELE-2406028-CV54
120/240v 28A 60Hz
3 or 4 Wire Connection
Ok the problem i have is, i turn the dryer timer and i have power and it makes the noise, i then turn the cycle signal on, and it makes the click.
But when you push the cycle signal for it to start, the dryer does not start. I have read a few posts on here, and i didnt find a perfect match for my problem. I did take the cycle signal switch out, and cleaned the copper in the switch, i also looked at the dryer thermal fuse, and also im aware there could be an issue with the switch to the door. Just not sure which it might be. Any ideas or help on this would be great, im hoping my issue can get resolved here, so i can get my part here also.
Thanks for your time…
[/B]
Well reading the posts helped a little, so as no reply from no one, im gonna go with my gut, and replace the fuse…
