Whirlpool Dryer has power but will not start
My dryer just stopped turning on. It has power. The switch and timer appear to be getting power. I ohm tested what I could, but do not see any obvious problems. (I believe I am doing this correctly according to your bulletin)
Any ideas as to what I should be looking at?
Thanks!
Thank you for your help. That was the problem and I ordered the part from you and installed the fuse. Somehow I missed that one when testing.
Now I have a new problem.
The dryer starts and runs but NO heat!
What should I look for as the most likely culprit?
The element appears to be fine.
Thank you!
I just wanted to thank you guys! I have a dryer that had power, but wouldn’t start. I read this post, downloaded the schematics, found the thermal fuse, bought a new one, and it works!!! Saved me money! Thank you!
How do I replace dispenser
