Help!!!
LG -With LE error
Get error every time washer is suppose to start spinning-
I have replace the- AP4438648 (4417FA1994G) - Drive motor stator assembly and AP4440680 (6501KW2002A) - Rotor Position Sensor Switch. I have checked the connections i.e no crack wires or connections. Any help would be great.
Thanks for reading
The LE error message on these LG’s is a terrible code, it essentially means something is wrong but the machine does not know what. LG techs have trouble with this error.
You are just going to have to start replacing parts one by one until you find the one that fixes it. I would start with the main control unit.
Sorry not to have better advice, it is just the way the LG’s are.
