hinge for oven
The upper door on my Jenn Air oven won’t completely close. The technician that came out said the hinges needed to be replaced and they don’t make the hinges anymore. I have searched and searched on-line for the hinges and can’t find them. I can’t believe I’m going to have to replace a perfectly good oven simply because of one part. Help!!! Does anyone know of a compatible hinge?
— Begin quote from ____
Unless you can find a place that still has the hinge in stock. We sold the last of both left and right hinges for this model several years ago. Sorry.
Part numbers for both hinges:
7106A020-60
12500043
— Begin quote from quechulo;78574
Don’t worry. Here’s a link to a website that has your hinge in stock.
http://www.**********************************************.com/Store_SearchResults.aspx?S=184188&ST=PBM
(hmmm for some reason it won’t let me type in the link so here it is with each word/symbol between http and the third / mark separated by a space. "http : // www . appliance parts world wide . com / Store_SearchResults.aspx?S=184188&st=PBM" Type everything starting with http and ending with PBM into your address bar with no spaces between any of it and it should take you to the page with your part on it.)
It is the same stock number as listed above and it’s around $16.00.
Good luck.:slight_smile:
Have a Maytag PAV 3240 AWW. The top agitator wasn’t spinning and popped up. I believe the directional cogs need replacing. Problem is that the agitator is unlike the agitator illustrations I have found on the internet. There does not appear to be any cover to pry off to find a nut. Can anyone explain how I can disassemble this agitator. Thank you.
