Jenn Air Hinge Replacement
Hi,
My hinge broke the other day on my oven. Through reading other posts, I am pretty sure I have the right part numbers for both the hinge and receptacle. However, I have no idea how to take the door off and get into the hinges. Because of how the hinge broke, I cannot close the door all the way. It is stuck in I think the broiler open stage. Any advice?
You can find the complete instructions in the service manual.
Here are the break down diagrams for the Jenn Air range http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=672433&&model_id=45156
I have a Maytag Gemini Convection oven that was in storage for a while. During that time in storage mice decided to make it a home. The insulation in toast! What I am looking for is information as to whether the part numbers I have found are all that I need to replace the insulation or if I need something more. What I have found I need is #AP4093954 and #AP4099083. Am I missing anything?
I have been without my oven for four months now waiting to be able to afford the repairs and would LOVE to have my oven back!
Becky :o
Hello, Were you able to eliminate the mouse odor from your range or oven? If so what did you do? I now have the same problem and do not know if I should try to get rid of the odor or buy a new one? Thanks for your help. Gail
