holes in clothes
After drying my knit fabric clothes get little holes that look like they have been cut in them. Things also get caught between the front wall and drum on the left side. Is there a way to fix myself?
Hopeful in Minneapolis
Been there done that…twice :smiley:
Piece of advice, go ahead and replace the drum bearing when you do the Felt glide assembly…otherwise you’ll probably be doing it again in 3 years…
http://forum.appliancepartspros.com/dryer-repair/485708-squeaky-clothing-catches-drum.html
And the drum bearing is easier than doing the seals. Hardest parts of the seals is scraping the old glue off so you’ve got a clean surface to mount the news ones to.
