Hi there–
We have a Whirlpool top loading washing machine that will only add hot water. I did some research and have done the following so far:
- Checked the water supply. Plenty of hot and cold water, plenty of water pressure.
- Replaced the water intake valve with a new one. This did not help.
- Switched hoses, which made the machine only add cold water, and not hot water.
- Tested the water temperature switch with a multimeter (I don’t have a lot of experience with this, but it read 120 volts), so I don’t think it’s faulty.
What are my next steps? Hopefully there’s something I can do short of calling a repairman or buying a new washer…
Thanks in advance.
-Mike
