hot water trickles into the machine
I have a kenmore 110.92293100 that is over 10 yrs old. When I do a hot water wash the water trickles into the machine, making the wash time extremely long… cold water washing is fine, and the hot water feed is good.
Thoughts anyone?
Dan C
Most likely the valve isn’t opening properly, try replacing the valve part #AP3096174
Nat
Remove the hot water hose and check the screen filter on the input side of the machine’s water inlet valve. It could be partially plugged.
If it is dirty, clean it. Do not remove it as it is there to keep crud out of the valve which could hold the valve open causing a flood.
Also, if it is clogged would be a good idea to drain some water out of your hot water tank. Use the drain at the bottom or the pressure release valve. Let it run till it is clear.
