Kenmore washer--hot water not getting in
The hot water is not able to enter the washer. The hose is not plugged.
[COLOR=#000000][SIZE=3]The water valve is most likely bad. You can confirm this by checking to see if the valve has voltage during fill. If it does and you aren’t getting water the valve is bad. [/SIZE][SIZE=3] http://www.appliance-repair-it.com/clothes-washer-repair.html[/SIZE]
[/COLOR]
