How do I find where the belt is located??
Im trying to locate how to find where I can access the dryer belt in my Roper Dryer. It was working fine this morning, then went back to put in next load and the drum isnt turning. Need help ASAP…thanks
Take out the two screws under the lint lid and you can flip up the top by inserting a screw driver or putty knife in the gap between the top and the front near the edges.
You can now take off the front panel by taking off the two screws that hold it to the frame. Make sure you disconnect the door switch and mark how the wires go. This will give you access to the drum and motor to replace the belt.
