How do I remove the panels
Our washing machine is showing an Lr code and will not spin out. I noticed there is a service bulletin to check for loose wires. Which cover do I take off to check for loose wires and is there any trick to getting the covers off. Once I get to cover off I’ll have more questions.
HappyPappy
Happy,
If you look at the breakdowns of your machine it will help you remove the panels. You’re probably going to start in the control panel, then remove the top panel and the front panel.
Hope this helps
Nat
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47812
We have a Whirlpool LER8648PW0, which is not heating. We have the back cabinet off and have taken the heating element out. The element does not look cracked, but does not heat outside of the cabinet either. How can we tell if this is an element issue or a thermostat that needs replaced?
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5140394
Here is a wiring diagram
https://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%203979703.pdf
Not sure how you tested it outside the unit so cannot say if it is blown or not.
[COLOR=Blue]
How can we tell if this is an element issue or a thermostat that needs replaced?[/COLOR]
Get a meter and check them.
First though turn your breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker. Symptom is no heat. Better yet check that you have 240 volts at the plug.
  1. Always remove power from the machine otherwise you could blow your meter.
  2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
  3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
