I have everything taken apart but can’t figure out how to remove the tub bearing, thats where the leak was so I have ordered the parts but can’t get it off. helpppppppppp PS I also ordered the stem repair kit.
How far did you get it taken apart?
Go to web site %url% for info on this dependable care washer tub seal and bearing replacement. You will not need the special spring stretcher tool, just use vice grips to get them back on. You can insert thick washers in the back springs before removal to facilitate re-assembly. Also, I use a steel rod to pound off the sleave bearing from the tranny housing. Lubricate the bearing with non-detergent oil before assembling.
