I am having a problem getting ice and water from the dispenser.
It will start to dispense the ice or water then stop. What should I look for?
Hi.
If the dispenser light is deeming when the lever is pushed it’s the sign of a bad main control board, located at the rear of the fridge under the metal cover.
The main control board WR55X10942
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5208602
Thank you. Post the results.
Simon.
