[SIZE=5]What temp is required on the freezer side for ice making efficiency? [/SIZE]
5 to 10 degrees F is what I always say.
[SIZE=5]Thanks for the reply. Yesterday I posted this [/SIZE][SIZE=5]Ice maker will not fill. Have water at door dispenser. When I switch the connectors at the water valve, then I get water to the ice maker and no water at the door. The water valve has been replaced as well as a new ice maker in the last 6 weeks. Have not been able to get the ice maker working. What should I do now?
[/SIZE]
