[SIZE=3]Ice maker Model IM6.[/SIZE]
[SIZE=3]What I have done:[/SIZE]
[SIZE=3]Changed Water Supply valve-No effect.[/SIZE]
[SIZE=3]Ice maker inlet tube is clear – no ice blocking water flow.[/SIZE]
[SIZE=3]Freezer temperature -10 F[/SIZE]
[SIZE=3]Ice maker light is steady green-not flashing[/SIZE]
[SIZE=3]Feeler arm moves easily back and forth-no apparent problem with spring mechanism.[/SIZE]
[SIZE=3]Freezer door light switch OK. (Water stops flowing to dispenser when door is opened)[/SIZE]
[SIZE=3]Ice maker jump started (turned ice maker off for 30 seconds; Pushed feeler arm back and released 3 [/SIZE][SIZE=3]times in 15 seconds. No water flow to icemaker.[/SIZE]
[SIZE=3]Any ideas? I am about to give up the fight. Thanks.[/SIZE]
