Replaced mother board and defrost termostat problem still exists ice refreezes and ice crystals forms on food
What is the exact measured temperature in the freezer?
— Begin quote from Gene;773267
It goes above 32 degrees when in defrost but not all the time
Replace the evaporator thermistor (on top of the evaporator). It controls the defrost cycle temperature.
- The thermistor WR55X10025
— Begin quote from Gene;773423
- The thermistor [part]WR55X10025[/part]
Thanks I’ll try that,I repair -80 degree revco freezers at work and this household refrig is kicking my butt!!!
Glenn
— Begin quote from glennbcool;773546
Glenn
Thanks Gene thermistor did the job!!!
You are welcome Glenn. I’m glad you were able to fix it.
