My icemaker stopped working but the water on the door works. I have replaced the Puriclean filter, vacuumed out under the frig (which I do regularly) replaced the valve inlet (the major one) Used the dryer on the spout where the water comes into the icemaker…what I am seeing is when I disconnect the plastic water line the water does not move-it doesn’t run out nor does it move backwards…What is the next step…I was thinking maybe a new icemaker but which one do I use…it says use icemaker assessory kit
Related topics
ICe maker not working | 1 | 1115 | July 26, 2011 | |
ICe maker not working | 1 | 1825 | July 26, 2011 | |
Water dispenser not working, ice maker does | 5 | 9711 | June 23, 2012 | |
Maytag icemaker stopped working | 2 | 2403 | November 23, 2011 | |
Maytag French Door ice maker stopped working | 2 | 3686 | August 3, 2010 |
