Maytag French Door ice maker stopped working
We recently moved, and my refrigerator ice maker worked fine, but now that I plugged it back in, it won’t work. Please help
— Begin quote from kayken1010;250165
Were the doors removed, to get the unit into the house/kitchen ?
Check and make sure the door switch is being activated when the door is closed
Check the harness, on the top left door hinge,under the cover, make sure it wasn’t knocked loose or unplugged for the move.
Was the icemaker turned off for the move ? check the off / on switch on the front of the icemaker.
Is everything else OK ?
Display on the dispenser is correct(not flashing,no erratic display) ?
Fridge and freezer temps OK ?
Water dispenser working ?
We need to start here, due the circumstances of the move.
Please do these checks and contact us if you need more asistance.:slight_smile:
