icemaker/water inlet valve check
A few months ago, the water from the door stopped working, couple of weeks ago the icemaker stopped working. both cases, dont see water is coming. Possibly I need to replace the water inlet valve, however I would like to know if it is water inlet valve or the wiring. Is there a way to check whether the water inlet valve is ok or not before I replace it. the part no. is 2182106.
thanks
