Have Whirlpool side by side with ice maker. A while back the ice maker was not working and I found ice jammed in the ice maker, after removing it worked fine for a while but now has quit working. It appeared that there was no water going into the ice maker so I replaced the water inlet valve and it still will not work. I checked the electrical plugs on the inlet valve and I am not getting any power on the ice maker side in the plug. Could this be a bad modular? Any help will be appreciated before spending more on further parts.
i am assuming that water is coming to the water valve, so the first thing i want you to do is to make sure that the tube that puts the water into the icemaker is not froze up. it is possible that it is frozen with ice. let me also tell you how to jump out the icemaker. pull the front off, and make you a jumper wire about 6 inches long, and just strip the wire back on each end, about a half inch, and then put 1 end in the hole marked m, and the other in the whole marked n, and if the icemaker head is good, it will take right off, if it does count till 12, and then take the wire out, and watch the icemaker, and see if when it stops you should have water in it. if the icemaker front gear does not turn when you put the jumper wire in replace the motor module. the part # is 8201515. tom
tried to jump out the ice maker as you suggested. No results, thus the motor module is probability bad? Did check out earlier testing points L & N and also jumper test points T & H and it showed they both had power.
— Begin quote from kayakcrzy;74231
You have it. Replace the motor module. Let me know how it goes. Tom ApplianceEducator.com
I replaced the motor module and and appears to be turning the white dial but still not working. There is water in the ice maker. I jumped started the new module as you suggested that I try on the old one but with no results. I have replaced the inlet valve and this motor module and have over $100 in parts already, do you have any other suggestions or tests to check for problem?
It appears there is water in tray but it is not making any ice. I have no ice and of course it is not dumping any ice since there is none.
It would have to be the sensor. Tom
Would I have to replace the entire ice making unit or can I just replace the sensor, where is the sensor located and would you know what the part number is? Appreciate all your help to date.
the thermostat can be replaced. the part # is 627985. this is usually the problem, when you can jump the icemaker out, and it works fine, but after that it won’t make any ice. tom
Still working on ice maker problem we have discussed. You thought at last post it must be the sensor. Today I have removed the complete ice maker unit and when I got to this there was no water in the tray. I did not replace the sensor and I still wonder why it is not getting any water into unit? I don’t want to replace the entire unit if you don 't think this will solve the problem. I just don’t understand why it is not getting any water? If I was to replace the entire unit what would be the part number on this model Whirlpool ED2VHGXMB10? I appreciate any further suggestions you might have in regards to my problem.
