installing new door handle
the handle broke off the door and there are two existing screws in place…how do you remove them and install the new handle?
— Begin quote from czina27;271189
Czina,
Here is your part number
[part]AP3178131[/part]
And here are the instructions for dismantling the door, so you can access the screws and replace the handle.
Good Luck,
[LEFT]1. Unplug microwave oven or disconnect
power.
2. Open the microwave oven door.
3. Pry the choke cover away from the top
door pin, and remove the top pin from the
pivot bracket. Lift the door off the bottom[/LEFT]
bracket, and remove it
[LEFT][FONT=ArialMT]4. Place the oven door front side down on a
padded surface.
5. Remove the choke screws from the door[/LEFT]
frame.
[LEFT][FONT=ArialMT]6. Starting at the top right corner (see the
round inset photo in the left column), pry
the choke cover out with a putty knife,
and unsnap it from the choke. Only remove
the top, bottom and right sides of
the choke cover at this time. You will remove[/LEFT]
the handle end of the choke cover later.
[LEFT][FONT=ArialMT]7. Starting at the top edge of the door near
the center and working clockwise, use a
putty knife, and pry the latching tabs of
the choke out of the door frame slots. Lift
the choke as you release the tabs so they
do not snap back into the slots. NOTE:
When you reach the handle side of door,
pull both the choke and the choke cover
away from the door frame, and then separate[/LEFT]
the two components.
[LEFT][FONT=ArialMT]8. To remove the door switch actuators from
the choke, remove the screw from each[/LEFT]
actuator.
[FONT=ArialMT][FONT=Arial-BoldMT]REASSEMBLY NOTE:
[/FONT]
[LEFT]When you reinstall
[LEFT]the door on the oven, insert the top pin into
the pivot bracket and press down on the pin[/LEFT]
until it snaps into place
[/FONT][/FONT][/FONT][/FONT][/FONT]
[/LEFT]
will use your notes to replace the handle once I review the part
— Begin quote from czina27;271224
OK,
Drop us a line when you’re through, and let us know how you did.
Good Luck,
