I am in the process of replacing a faulty water valve. it appears that I simply push both the ice maker line and the door dispenser water line into the valve. I have done this but in one of the lines there is a very slight drip coming from where the line goes in to the valve. should I have made a fresh cut in the line? what purpose does the plastic cap which sits in each of the holes where the lines fit in? thanks.
Related topics
GE Profile Fridge leaking water - warping the floor! | 0 | 3573 | December 13, 2009 | |
Water valve | 3 | 1140 | December 17, 2009 | |
Replacing water line to dispenser in door! | 0 | 4348 | May 2, 2010 | |
GE side-by-side water dispenser tube install | 2 | 6351 | April 4, 2011 | |
GE SideBySide Water Dispenser | 2 | 2587 | January 1, 2011 |
