intermittent Spark Igniter
I have a GE JGP328BEC2BB gas cooktop that has one burner that usually will not light up. When I turn the bad burner knob on, all 4 igniters start sparking. When I turn the knob far enough for the gas to start flowing, the three good burners continue to spark but the bad one stops sparking just prior to the gas flowing in it. I don’t think the gas flow on the bad burner is starting any later than the other three. Occasionally the bad igniter with spark 1-2 times after the gas is flowing for 2-3 seconds, but this is pretty rare. Wondering if it might be the spark igniter or the igniter switch and harness assembly. Any thoughts would be greatly appreciated.
