OK, so last week I got on here and described my problem Frigidaire washer. The problem was, and still is, that it will not go into final spin. The wash and rinse cycles seem ok, but with about 9 minutes left on a normal wash, it just shuts off as if it is done. I checked the door lock assembly, it is fine. I checked motor resistance, it is fine per specs on the schematic. I replaced the motor control board, purchased from you guys, and the problem still exists. I am not an appliance repair person and now my wife says a real repair person has to work on it. My life is spinning out of control. What next?
Dear Gatorgirl,
I read your post regarding the door lock assembly and am hoping you will see my post here. I have the same problem. I actually ran all the diagnostic tests myself and get error code 47. Everything on the machine works fin except it will not drain completely. I can even force spin the water out. I had the repair guy here. He told me it is the control board and will cost around $175. I showed him the numerous posts that this could possibly be the door. He told me his little electronic reading comes out normal. I still believe you are right. I was wondering if you could tell me where you got the part and how much it costs. I would at least like to try this first.
Anyone else having this problem and has ordered this part could you help me?
