Anyone know how to replace a tub bearing kit/ seal kit on this unit? Seal was leaking and during spin cycle tub wasn’t spinning unless I push the transmission. Belts were starting to slip.
Thanks for any help,
Jeff
Hi Jeff
Here is the service manual which will take you through the process.
http://www.servicematters.com/maytag_library/docs/16010373%20(16001145).pdf
Good luck
Well thanks, you do the work and we get the credit. Is this a great country or what!
Glad it worked out and thanks for updating us.
