My Jenn-air oven shuts off after only a few seconds. It seems to works better when it’s warm. If you can get it to start heating it will work normal. This has Been going on for about a year off and on. It would normaly start working after a few try’s but this time it will not.
Well after jiggling all all of the wires I managed to get the broiler to turn on. After it gets hot the oven will work like it should. That will let me finish my dinner that I started preparing hours ago but this problem has to be fixed
Hi.
What is not working - bake,broil or both?
Would you please be a bit more specific on what did you do to make it work.
Thank you.
Simon.
Neither one would work. after I just wiggled all the connections the boiler finally work. After the oven got warm the bake would work
Can you please be more specific on what connections exactly you wiggled?
Simon.
Every wire and connector behind the front panel
