Jenn Air Range
A friend gave us a Jenn Air model FCE30610W flat top range. The clock works and the panel lights works. The burners do not heat when turned on. The oven does not heat. You can set the temp, it clicks and acts like it’s going to start heating. It shows a temp of 100* but does not heat any further. Any ideas?
Are you sure you have 240 volts to it? Sounds like you are missing 120 volts.
http://www.appliancepartspros.com/wiring-information-parts-for-jenn-air-fce30610w.html
