Jennair Cook Top
The fan on my Jennair downdraft cooktop (black) has quit. I have oredered a switch and new knob from this site. [SIZE=4]How is the old switch[/SIZE] [SIZE=4]removed?[/SIZE] I see two screws holding the switch assembly to the frame but when I removed the screws, the assembly did not lift out. Does anyone have some ideas before I snap somthing off. Thanks…Charlie
Pull the panel outward and then lift it up.
Charlie,
The model number you posted does not come up. Verify and repost it, please.
Gene,
Thanks for caring. My model number is JED8430ADB Sericl Number 19132422EL. When I was trying to find the part number for the fan switch, I also had trouble pulling it up. I called JENNAIR and they used JED8430ACW to pull it up but said it was the same mondel only mine was black. I hope this helps…Charlie
Charlie,
According to the break down diagram looks like you have to remove the main top to access the switch what requires the cooktop removal from the countertop.
My Electric Built-in double Oven seems to have no power. The Breaker is ok. Is there a fuss within the unit that may be broken? Or is there a problem with the electronic Oven Control?
