Kenmore 80 Series Won't Agitate Will Spin
My Kenmore 80 series model 11.27892790 won’t agitate. Well, it was agitating occasionally when I messed with the cycle select knob (moving it to a different cycle), but now it won’t agaite at all. It fills, drains and spins. On the rinse cycle, after completeing the final spin, it adds some additional water - not a full tub, but just enough to make the clothes wet. Timer? Can I fix it myself? I’m a waitress with bad credit, and can’t afford a new machine.
I’ve replaced the dogs (which needed replacing anyway), but it didn’t help.
TIA
Does the motor run when it should agitate or it’s silent?
How do I tell if the motor is running?
You can hear it as you do when it’s drain and/or spin.
No, it doesn’t sound like the motor is running - totally quiet. I can only hear the timer if I put my ear up against it.
P.S. Sorry for the delayed resonse - had to work.
Sorry for the delay as well. I’m assuming the part you called "the cycle select" is the timer. Looks like this part is the culprit.
