So, I have had my dryer completly apart. I have tested the thermistor and thermal fuse both in working order.
When i push the start button the dryer makes a loud buzz and sounds like it is trying to start. Everyonce in a while it will start on the first try but if i open it and try to restart it, it will not start.
Wanted to see if there was anything I could do before I order a new motor.
Hi.
Most likely it is the motor and only thing to check is if the blower wheel is not jammed.
If you need parts breakdown, provide the model number.
Thank you.Post the results.
Simon.
I have taken the motor and blower completely out there was a small amout of build up but nothing jamming any moving parts. After cleaning everything inside and out I put it back together and same problem… I dont have the model number sorry
Hi, Tiffany.
To get you the correct motor I need the model number.The tag is on the door or the frame around the door shut.
Simon.
I know the motor is part number 3395654, but i was hoping there might be something else I should check first… I have ordered a new motor I will let people know if it works in case they are having the same problem.
