Kenmore 90 won't agitate but will spin
If I put in a reg load the washer dulls up but will not agitate. Then go’s to drain then spins ok. I thought it was the motor but that works well. It was working for a while ok on small loads but not it won’t agitate on any cycle. Any ideas. The washer is a great shape it had regular maintanance but the policy ran out and I think I can fix this with your tech help. Thanks
Hi.
You need to determine if this is bad agitator or transmission.
Remove the agitator and see if the transmission shaft is turning back and forth and you can’t stop it by hand.
If that the case - replace the agitator 3947517
If you can stop the shaft or it’s not moving at all - replace the transmission 3360629
Post the results.
Simon.
It works on perm press ok and if I unplug unit and plug it back in sometimes it works. If I play wit timer sometimes I get it to work. I don’t think it agitator
Hi.
It wood be very helpful if you share with us all the info about the problem in the beginning.
Based on the info you provided it’s a bad timer
3951770
Simon.
