Kenmore Dryer Not Heating After We Did Changed the Rear Drum Felt Seal
My husband and I recently changed the rear drum felt seal on our Kenmore dryer through the help of one of your videos. When we put everything back together though, I noticed the dryer runs, but doesn’t dry our clothes anymore. The dryer heated fine before we changed the seal, so my guess is that the reason it doesn’t heat is related to the repair we made. We went back through and made sure everything was put back correctly, but it still isn’t drying. My husband went ahead and used our ohmmeter to check the cycling thermostat, the high limit thermostat, the thermal fuse, the heating element, the timer, and the motor and they tested ok. Any tips on what to try next?
Attached is the wiring diagram in case you do not have it.
First I would check the power.
The heating element requires the full 240 volts.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
Next I would check the wires at the timer (Timer Switch 2).
Then the red wires at the motor’s centrifugal switch.
Set the unit to timed dry with heat.
Unplug it.
Attach one meter lead to L1 of the line cord and leave it there.
Set the meter to it’s most sensitive resistance scale.
Now work your way back through the heater circuit until you find the open.
