Sorry but I do not know where you are getting the switch numbers that you give.
The motor runs off of half the line (120 volts) but the heater requires the full 240 volts so start by checking the power.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on. Be careful as 240 volts is lethal !!!
