Kenmore/ Whirlpool gas dryer 27 in. Ser # MP1204902
The motor and drum turn, no clicks heard. Tried moving the heat selector switch on the front panel with no success. Tried in both timed dry and heat sensor mode with no success.
Took the front lower panel off. Disconnected 110v leads to the burner assembly and attached meter in AC setting to the dryer side leads. No voltage detected when motor and drum are turning.
Found one fuse and the thermister just downstream of the blower fan. Fuse shows 0 ohms and thermister shows 8500 ohms and moves lower from heat of my fingers. Checked the 205 degree thermostat on outside of heat tube above burner; shows 0 ohms. Some web sources show more thermal cutoffs/fuses, but I don’t see any.
Can the broken belt switch be bad and still allow the motor to turn?
What do I go from here? Thanks
